Hooker Header 5115 / 5116 fit question?
Mopar Racers Forum
  1. 1969GTS340
    1969GTS340 FABO Gold Member FABO Gold Member
    326
    66
    Apr 13, 2014
    Akron, NY
    Local Time:
    12:28 AM
    I just came across a set of 5115 Hooker Super Comps that are listed to fit E-Body. Hooker lists 5116 for A-Bodies. Has anyone installed the E body header on an A body? What kind of conflict would I expect to run into? This is a 72 Demon 340 application with manual steering.
    Thanks FABO
  2. rumblefish360
    rumblefish360 so close yet so far away
    33,805
    5780
    Jun 21, 2005
    New York, on a Island
    Local Time:
    12:28 AM
    Hummmm, I have the E body headers on a shelf and there kind of wide IIRC. I could snap shots tomorrow for you to see mounted on a 318 and! Vs standard horror show headers that are my test mule engine run stand headers.
    Oh! There also a 1-3/4 tube header....
  3. 1969GTS340
    326
    66
    Apr 13, 2014
    Akron, NY
    Local Time:
    12:28 AM
    Thanks Rumblefish. Never thought about the width being the difference but that would be a big issue trying to squeeze them between the fender wells. I havent come across a Hooker Header tech number to call for the spec.
  4. rumblefish360
    33,805
    5780
    Jun 21, 2005
    Local Time:
    12:28 AM
    I’ll take some pictures tomorrow if all stay well around here. It is more Of anT bar issue I would think.
  5. rumblefish360
    33,805
    5780
    Jun 21, 2005
    Local Time:
    12:28 AM
    @1969GTS330
    Sorry for the delay....
    The standard 1-5/8, 1 size fits all header. The brand doesn’t matter.
    A0EDE19A-8373-4875-8030-A645BEEF0A1D.jpeg 7CE9196E-327B-4734-8092-C64991A6829B.jpeg 9161C247-02B8-4D3D-AA0B-764676372393.jpeg F41C0203-2A4B-437E-9E58-BFFC03E610E7.jpeg B8FC0C5D-9F6B-4D17-AE28-ADB0F6E21996.jpeg 8FD42F48-5DD3-492D-8131-8E528959483F.jpeg C45542CD-A5F3-4A2B-AAB1-74226C675BA6.jpeg 9A2669D8-959F-4682-A2B6-7AF1DB388100.jpeg
    • Thanks! Thanks! x 1
    • rumblefish360
      33,805
      5780
      Jun 21, 2005
      Local Time:
      12:28 AM
      B & E body Hooker Super Comps w/1-3/4 tubes, 3 inch collector that is noticeably longer.
      Passenger side bent vey bet similar.
      Drivers side very differently.
      B0ACD434-6B9A-4C9D-B7DD-B51D9550091F.jpeg 6479F1A0-8576-4510-96AD-B97B1D7A0B5E.jpeg F3995347-67BE-4B32-9D27-1B81ED1C6129.jpeg 20B4454B-7640-4C45-ACD3-B47319A38C59.jpeg 0038BD26-081E-46D3-9DB0-38E465F5AC08.jpeg
      • rumblefish360
        33,805
        5780
        Jun 21, 2005
        Local Time:
        12:28 AM
        Top 5 are the passenger side
        Bottom 4 are the drivers side
        ED0E0C2F-455F-4FFB-8626-4A362DE92FDF.jpeg 2C47B680-F893-485F-A589-C82E5E6EBB2F.jpeg 6D207383-12B5-45A6-810D-2074552315FF.jpeg 3F929DC2-9E4C-48E1-A2FC-7911426F5402.jpeg 0E541E05-1CCB-4297-B22B-4AE02EBF4027.jpeg ADCF7295-D19A-4150-84EA-EFFDA6D2D9CB.jpeg 573017FE-EA9F-4923-A2AB-C7F7F8DFBC1A.jpeg F8090B09-3B37-4007-A8A6-E4F7566D0E66.jpeg FEF78EE9-8DCF-4AB8-9DB0-64B10168EB98.jpeg
        • rumblefish360
          33,805
          5780
          Jun 21, 2005
          Local Time:
          12:28 AM
          I think this is where the fitment issue comes in. Where normally the 3 tubes on the 1-5/8 header go in front and under everything, creating that large opening for the front end and drag link to go through is t really there on the 1-3/4 B/E body Super Comps.
          • 1969GTS340
            326
            66
            Apr 13, 2014
            Akron, NY
            Local Time:
            12:28 AM
            That is one impressive demonstration! Since my original post, I did find another set of HSC but these are made for A-Body. I'll try adding a pic in few minutes but I think they are shaped more along the lines of the 5/8 set in your pics, but they are 3/4.
          • rumblefish360
            33,805
            5780
            Jun 21, 2005
            Local Time:
            12:28 AM
            Thanks, I try and help my best.
          • 1969GTS340
            326
            66
            Apr 13, 2014
            Akron, NY
            Local Time:
            12:28 AM
            This set is for an A Body.
            42472037_2104243806253572_1966689808583491584_n.jpg 42472985_2104243642920255_3572573618086871040_n.jpg
            • 1Fast340
              1Fast340 Well-Known Member
              1,167
              366
              Dec 30, 2011
              Sweden
              Local Time:
              5:28 AM
            • 1969GTS340
              326
              66
              Apr 13, 2014
              Akron, NY
              Local Time:
              12:28 AM
              I'm thinking 1.750?
              • Like Like x 1
              • 1Fast340
                1,167
                366
                Dec 30, 2011
                Sweden
                Local Time:
                5:28 AM
                Hard to say from a pic of a measuringtape but i would still say 1.875. I cant think of any other Abody smallblock header with its tubes routed like the ones shown except the disontinued Hooker #5303 and those where only made in 1 7/8" and are a multi piece adjustable header just like the one pictured,considering how ends can be deformed and the small tollerances we are looking at,try to measure with a calliper on a straight and round secton of the tubing. I may be wrong and one should never say never but i cant think of any other header than the 1 7/8" tubes from Hooker.
              • 1969GTS340
                326
                66
                Apr 13, 2014
                Akron, NY
                Local Time:
                12:28 AM
                They are still bring shipped to me. Once they arrive I'll check with a caliper to verify what these are. I'm leaning towards them being 1-7/8" as well, which my engine may have to grow into.
                • Like Like x 1
