[WANTED] Horn contact ring
cdstl
STL
I am look for a better horn contact ring than the one that I have. I'm not sure what the proper name is.
Thanks
Did you happen to mark where the signal cancel stud was when you took it off. :D
Turn the wheel upside down, top of the wheel on top, put the stud in the 2-3 o'clock position.
I was messin with him. :D
Which is it?
2 or 3? :D
I have one sitting right here but this one has a blade style connector instead of an attached wire or I would have offered it.
At least 1 member here has rebuilt the insulating plastic portion using 2 part epoxy and dremel tools
