So, how much airflow increase through the cylinder head, will give the same horsepower increase as raising the compression ratio one point? When does airflow win? When does compression ratio? Where's your proof, huh, who has tested this?
Sounds like nobody knows, doesn't it? Alright, an increase from 8.5:1 compression to 9.5:1 compression or 10 cfm all across the board. This means 10 cfm increase at .100" lift all the way to .500" lift, or an increase from 8.5:1 to 9.5:1. Which will give a greater average horsepower increase?
Did anyone really think I was talking about 1:1 or 100:1?
Effective or running compression=dynamic. Just different wording. 8 to 1 effective is not out of pump gas range. I shoot for 8.5 to 1 and run them all the time like this, iron or aluminum, on 93 octane pump gas. If the engine is set up right, you wont have any issues.
interesting way to expose those who do and those who dont
Im my eyes and going back thru some of my dyno sheets and what I have learned over the years Id say they will come out equal. 10cfm gain or 1 point compression, the same power. If you have an engine that can breath better, its effective compression will increase, as it is getting more in the cylinder, more to squeeze. If you run a smaller space, more compression, you get the same effect. Ill take more compression as the engine will generally run more efficient with higher compression. Less fuel, more power.
This is why Circle Track 2bbl engines(or NASCAR restricted engines) can run 12 to 1 static compression, or MORE, on a lower octane than what you might think. They can not fill the cylinder as much, so they have to squeeze it harder to get the power. The effective compression may only be 8 to 1.
