momoparman
MOISMYHOME
Just so I am clear, your price is $219 shipped to our door plus 10% discount so its $197.10 shipped.
Is this correct?
Is this correct?
Is this correct?
OK
I also see on one post you say they are clocked 15 degrees and on another you say they are 20 degrees.
What are they?
I will say that we have done a redesign on our B&E body torsion bar to a 20 degree offset.
These bars will allow for more adjustability and improved handling capabilities. We have redesigned the clocking of the bars to a 15 degree offset
What is the approximate wheel rate of these bars?
Exactly. Can we get an approximate wheel rate?
I will try to get that for you today but I can't guarantee as I am out of the office. If not I will have it for you Monday.
Thanks
James
I have been trying to get an answer for you on the wheel rate from the engineer that designed them for us. I know that 1.03 for the B Bodies come in at a wheel rate of 209 I would assume that with the A body bars being shorter but the same diameter the wheel rate would be in the area of around 230 to the 250 range. I will keep on the designer to get an answer.
Thanks
james
James, will the new bars allow me to drop the car? I'd like to go at least 2" (or more) lower than factory ride height.
Thanks
Mark
There was a guy (can't remember right now who it was) but he recently listed the 1.03 zero clocked bars for sale.
Those are what you need to have tighter bars and drop it.
I'll look for that post.
Here ya go.
Contact him and see what he needs for them, as these were the original zero clocked 103's for lowering.
http://www.forabodiesonly.com/mopar/showthread.php?t=296250
Thanks
Mark
