Picking a cam without any understanding of one should follow these guide lines as a basic "How to choose a cam" for there car. Remember that cams perform in a certain rpm range and as the bigger they get, the rpm range goes up.
The cam should work with the intended tire size/gear ratio, stall of the converter & over all engine package.
Ask your self these questions;
At what rpm do I want to cruise in. As in driving down the highway.
What is the min. rpm (of the cam) I can use with my converter and gear?
What is my engines compression ratio and will it work OK with the cam?
Can my heads handle the cams lift? Not in flow term but actual mechanical limitations.
Knowing your gear ratio, tire size, stall converter is the first step.
I could recommend what I think is an excellent match for engine parts to make the most enjoyable street ride engine, but unless you have at least a 2000 stall converter & a 3.91 gear, it would be pointless and your car would be very sluggish until about 2000/2500 rpm.
Stock converter with numerical gear ratios lower than 3.21?
Look at cams under
[email protected]
Stock converter & gear ratio above 3.21 Look at cams under
[email protected] duration
Add a converter to 3.21 & better gear? Cams to
[email protected]
