This should be a sticky. You didn't know something. You asked. You LISTENED. Way to go, dude. You're little motor is gonna come out great. Cause you are FAR from a dumbass. Kudos.
4.03x.0065=.026195 ring end gap
.0015-.0020 is the piston to wall gap.
Make sure you gap the top ring only to .026
edit:maybe find a new machinist or atleast one that deals with performance parts.
Your engine could have been destroyed.
No harm no foul,glad we were able to catch it before something bad happened.just remember engine builders and machine shops arn't always the same thing and mopars are less known around some shops so check you instructions on all you parts and also ask alot of questions here.I could have very well misunderstood what he was saying too. I get confused with numbers flying around.
thanks for this diagram i have set my rings a little diff but close to this with no problems but from now on i will follow this ....This is just a reminder as you may already know this. You need to stagger the gaps also. This diagram may not be exact for your application, just a reference so you know what i'm talking about.
First - the 2nd ring is not a compression ring. It's designed from the start to be an oil scraping ring. It does not hold pressure well as a result.
Now - There are two schools of thought on the 2nd ring & this will be a little odd simply because of the KY hyper special gap considerations:
One group like to use the same gap or smaller than the top ring. The 2nd ring does not get as hot because of it's placement and the oil that bathes it as it works. IMO - you can't go wrong that way. But, you may be giving up some power at higher rpms.
The second group, of which I am a member, is that the 2nd ring while not designed to hold pressure, does have some pressure built up between the first and 2nd rings in normal operation. When that pressure gets high enough, it can push the top ring up off the piston's ring land. When that happens, the top ring loses sealing ability and you get blowby and less power. A larger gap in the 2nd ring allows the top ring to do it's job better over a wider operating rpm. So the second group believes in running a larger ring gap on the 2nd ring. I use 25% as the multiplier. So an engine with a .016" top ring gap gets a .020" 2nd ring gap.
That being said - with KB's special top ring gap requirements - the 2nd ring should be gapped as if the top ring were gapped "normally". So where the "normal" top ring gap would be around .018, the 2nd ring gap should be around .023".
So if I were gapping your rings - the top would be .026", the 2nd would be .023.
. I can BARELY feel it if I run my finger nail along it, but can't feel it when I run the tip of my finger along it. How detrimental is that/how bad did I mess it up?
Kyle
thats what i set mine at .26This is why I admit to being a goon with this stuff and save myself from $3,000 of heart ache. Going back to that page for another read. Thank you, sometimes I just need to be smacked in the head like that.
He went over the difference in a regular piston top ring and a KB top ring,looks like it was a little confussing for some.He states that the second ring should be gapped 25% at what stock type top ring would be not what a biggier gap KB top ring is.First - the 2nd ring is not a compression ring. It's designed from the start to be an oil scraping ring. It does not hold pressure well as a result.
