How do i tell if its a magnum engine?
78kitcar
Cleveland Ohio
So I'm buying a 360 magnum engine from a 94 ram off a member here and i want to make sure its a magnum engine how do i tell? Its not that i don't trust him but would like to know for myself.Are all engines after 91 magnums? Thanks guys wish me luck :toothy10::toothy10:
Only the Magnum blocks have the crank sensor at the passenger's side rear of the block.
If it's complete, it'll have the tall "kegger" intake, also a dead giveaway.
'92 360s were still LA engines.
Mark.
Magnums' have 10 bolt valve covers. toolmanmike
No fuel pump provision on the timing chain cover, vertical intake bolts, 3 extra mounting holes on the sides for the truck motor mounts.
