On most of them, to change fan direction, just reverse the power leads.
switch the wires around, I have a couple of extra fans in my garage that depending on which wire is hot determines which way they rotate
Be careful, here. Unless the fan blades are "straight", with no airfoil cross section, they will move FAR less air. If the blades are curved, you would have to ALSO physically turn the blade around front to rear
See the curve here? You are looking at the convex side. The ONLY direction this blade can go which will be most efficient is to the left, or CCW
Look at your mechanical fan. The convex side is ALWAYS towards the front of the car. If you were to physically turn the blade around on the pump, it would STILL PULL AIR the same direction, but it would be vastly less efficient, and move far less air
Another example below. The way this fan lies, the cup/ curve of the blades dictates that it rotate to the left, CCW, and will pull air UP toward the viewer
IF YOU TURN THIS FAN OVER and rotate it CCW, it will still pull air the same direction, but will not move nearly as much
