how much fluid in new T/C
Indy dart
Member
I am putting a new converter in a rebuilt 727 and was wondering how many quarts were needed for the converter on initial install. I guess I am priming the converter. I have asked three people and get different answers. Thanks
i would fill it up so that when u tip it on its side it starts to run out. thats enough to get it primed
also make sure u get it in there three "clicks"
Can you clue me in on the three clicks? I can feel the neck of the t/c slide on the shaft and then through the seal but no clicks. It must be engaging something because the trans line connection is pumping a bit of fluid out. Thanks for the help guys, this gets a bit frustrating when I know so little but want to do it myself.
