How much horsepower
Well great answer! If you don't know then you don't have that problem. And I don't have to spend money to find out what all the hullabaloo is about, with all-aluminum AFB-type carbs.
It seems there are several members on FABO who are having troubles with what they believe is the gas boiling away during 30 minute shut-downs. Generally that is referred to as the fuel percolating away.
I tend to disagree with that diagnoses. But until more guys like yourself, report in with no troubles,I guess the jury is still out.
What fuel are you running? and is that RPM an RPM-AirGap? Got headers? What engine temp are you running? Cold air intake? A ventilated hood?
Running 93 octane, just a regular rpm performer intake, stock hi po manifolds. Run 180 in winter and maybe 190 in summer with stop and go, have dual functioning scoops with the open spots on the air cleaner. Also have heat sleeve on the fuel line from about half the car all the way up to the carb as well as a heat shield on the pass rear where the exhaust is closest to the fuel line
