Bores +.060
Eddy Performer RPM Alum. heads 2.02 x 1.60
Eddy Air Gap intake dual plane
Eddy 650 Carb
Comp Cam XE284 hyd.
Comp. Ratio approx. 8.5:1
Balanced rotating assembly
Stock 1972 360 cast iron exhaust manifolds
Probably a 2-1/2" Flowmaster exhaust system
For those of you that have gone thru this, about how
much power and torque should I expect at the wheels?
Thank You for your input
Eddy 650 Carb
Comp Cam XE284 hyd.
