How much trans fluid ?
AdamR
Big Member
Bethel, CT
How many quarts of trans fluid do I need to pick up for my 904 ? Its got a deep pan on it.
Is it bone dry? Converter dry?
More than you'd think!
Its pretty much empty. I drained as much as I could from the converter. Plus an extra 2 quarts for the pan. The converter is only an 8" though so it wont hold as much as a stock 11"
I know they hold a good amount, Just not sure how much.
I'd buy a case just to be on the safe side then you'll have a few spare quarts.
I'd start with about 2 gallons (8 quarts). The nice thing about your pan is that you can drain it a little if it's over.
Thanks Guys.
Chris, the bad thing about it is its chrome. Should hold the heat in nice.
Buy a case! The first time I filled my 904 with deep sump pan I either used a whole case or pretty close to it.
