XtechX
Active Member
Right now I'm not sure how to remove the lca to change the bushing.
Please tell me if Im correct here...
1. Put car on jack stands 2. Remove wheel 3.Loosen TB adjusting bolt until all pressure is off the bar. (All pressure is off now ,right? and when I continue nothing is going to come unglued and kill me??) 4. Jack up lca and unbolt the shock. Now what do I do? Do I need to remove the clip at the back of the TB and push it back? Or can I just unbolt the pivot shaft and take the lca off and replace the bushing? Also I assume I will need to pull the rotor and caliper etc to make the job go smoother?
Any help or advice would be great, this is my first Mopar suspension experience and is alot different than I've ever dealt with.
