70dart
Wireweld,
What combo of internal components are you using in this combo, such as pistons, rings, rods, cam, crank, heads etc. Your numbers are impressive congrats. You are in the ball park that I want to be in with my future 340 stroker build. By block is stock bore but will need some cleaning up so I will probably bore out to 30 over and I want to use my 2.02 valve X heads. The rest of it I have no idea yet, but your build helps, thanks alot! :thumbup:
