huges 8 blade water pump
Is there something wrong with the stock one?
it alllllll adds up. Put it twords the first oil change you do right after you fire that engine up, rather than wasting it on a water pump that wont be any better than a stocker. I run a stocker with a cavitation plate on it, haven't gotten any hotter than 195 in BLAZING hot temps with my setup. 180 is the norm under 100*F outside.
Just my 2cents
so your saying that the one thats on my 318 will be fine for the 360? instead of buying a new water pump?
There the same pump..
Theres basicly 2 pumps. A/C and non A/C.
Again, whats wrong with the pump now? Nothing? Then why purchase a new one?
If it does not cool the engine, theres other areas to be looked at as well.
How is the condition of the current rad?
its good
i just thought for the NEW 360 il be putting in that i should get a new water pump but i guess not
