Hughes roller cams
Chrippa
Anybody using a Hughes Engines roller cam? Any thoughts about them, quality, performance etc ?
Any difference from say Comp or Cranes roller cams ?
Im gonna go for a solid roller cam! :)
Thank you! :)
They all do the same thing. Find one that matches the heads flow numbers, and will make peak power where you want it. Scott's pretty good with helping there too. What you want to be careful of is the lifters, and clearancing the tie bars. Also, you are bushing the lifter bores, right?
Didnt really know about bushing so thanks for the reminder ;)
Who sells them?
Lifter bushings? Well, your shop can get them. It's amchining operation, where the lifter bores angles are corrected, and the bore itself is bored larger, then a bronze bushign is installed in the bore, and finish honed to proper size. With rollers, should a part fail between the valve stem and lifter, or the lifter itself, the bushings keep you oil presure up. The cam profiles kick the lifter out of it's bore at that point. Otherwise, by the time you figure out what happened, the lower end is beat up. It also correct a lot of poor factory work that is very common in factory blocks. At my shop, it costs $300 plus the bushings for that operation, many shops do not have the equipment to do it tho. So ask first. A hydraulic roller does not need that procedure, only solid rollers. And yes, you can run it without them, just be very careful with lifter choice,and IMO, it's a poor gamble with a street car.
