Need little help here,can anyone tell me if this is shifter for mopar.
If so what body and year. that's like a universal hurst comp plus shifter, lever holes are larger than factory rods, must use bushing kit pac #3327302, levers ending with the #s 70 71 72 show its for a body 68-74 b body 68-70 (must use two hole shifter) not slip in, the e body and 71-up b body has lever ending with the #s 78 79 80 hope this helps
Thanks.
Thanks all,seem I have no need for it,what should it worth if I sell it?I checked, my "A" body Competition + I bought back in the day, and it has the same shift levers as the one you have. You need the Competition + bushings and pins, an "A" body mounting plate, a set of A body transmission arms and rods, and a handle. Should be nice.
