Swe.cuda65
New Member
is it possible to put hydraulic lifters on a solid cam?
know it works the other way around but dosent hurt to ask
........................pro's= more lift as u don't loose ur valve lash, quieter running, cons=less rpm capability as u can run into lifter pump up...........kim........
...................I'm just using the old cast iron adj rockers....pulls really strong to 5800 rpm.......I have used that cam with the factory non adj rockers b4....really good till 5400 rpm.....I shoot for .006 preload..kim.......
