Hydraulic master cylinder - Firewall flex solved
Manual Transmission & Clutch Discussions
  1. Jason Wenger
    Jason Wenger Active Member
    30
    10
    May 23, 2017
    Cedar Rapids, IA
    Local Time:
    5:44 AM
    IMG_20200819_134818.jpg IMG_20200819_134826.jpg IMG_20200819_134920.jpg IMG_20200830_151208.jpg IMG_20200830_150736.jpg IMG_20200830_150730.jpg IMG_20200830_150725.jpg
    Anything worth doing is worth overdoing.
    • Like Like x 2
    • Thanks! Thanks! x 1
    • 19Greg69
      19Greg69 Member
      15
      11
      Aug 14, 2017
      Connecticut
      Local Time:
      6:44 AM
      Outstanding job!!!!
    • MoparMike1974
      MoparMike1974 FABO Gold Member FABO Gold Member
      2,986
      2228
      Jun 16, 2017
      Maryland
      Local Time:
      6:44 AM
      Nice solution. The factory power brake setup had two or three braces that went to the firewall and inner fender. I can tell you, without them the master cylinder moves about 1/2" left and right with each pedal push. Wouldnt take long for the firewall to crack.
    • moparmat2000
      moparmat2000 FABO Gold Member FABO Gold Member
      18,465
      7420
      May 13, 2010
      Grand Tetons
      Local Time:
      5:44 AM
      That looks great. I could see you being able to make and sell quite a few of these
    • Magnum Valiant
      Magnum Valiant Active Member
      41
      22
      Mar 14, 2020
      United States
      Local Time:
      6:44 AM
    • Magnum Valiant
      41
      22
      Mar 14, 2020
      United States
      Local Time:
      6:44 AM
      Did you cut a hole for the clutch MC, or was it already there, speedo cable?
    • Jason Wenger
      30
      10
      May 23, 2017
      Cedar Rapids, IA
      Local Time:
      5:44 AM
      Hah! Took me more than a day, all hand work. -- Need to add a photo, the back side required a couple hours of careful slow grinding to match the profile of the firewall. Can't imagine that's quite the same for any two cars in the same year, let alone generically. It'd be tough to produce in bulk.
    • Jason Wenger
      30
      10
      May 23, 2017
      Cedar Rapids, IA
      Local Time:
      5:44 AM
      Yes, used the same hole saw I used to make the hole for the clutch master cylinder in the plate in the bracket. There's about an inch of the master housing that sticks out past the mounting plate, so the hole in the firewall has to be big enough to clear the master and the rubber boot, not just big enough for the pushrod alone. That's another reason I wanted the bracket like this, making so large a hole in the firewall, I wanted it sealed up.
      The firewall there has part of the bend, so it's not a hole through a flat section of firewall, but it's the only place you can do it. I still like this a lot better than putting the clutch master through the firewall hole for the clutch throwout pushrod, which requires the cylinder to be very low, and at a very steep angle and also to interfere with the wheelwell. I couldn't see any way at all to make it fit that way in fact.
      The manufacturer says you want a 6:1 pedal ratio, so that, based on the geometry, requires the centerline of the clutch master to be about an inch lower than the centerline of the brake master. Hence the dogleg shape. Now let's just hope it actually works out.
      • Like Like x 1
      • RustyRatRod
        RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
        69,419
        43957
        Jun 7, 2010
        Georgia
        Local Time:
        6:44 AM
        Yeah, I imagine that'll do it! Nice work!
      • dogbreath
        dogbreath Well-Known Member
        349
        128
        Nov 29, 2009
        Local Time:
        5:44 AM
        earl a or early b ??????????
      • Tooljunkie
        Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
        17,570
        18092
        Jul 22, 2017
        Manitoba
        Local Time:
        5:44 AM
        Well done! If anything you have shared a solution to a common problem.
      • Jason Wenger
        30
        10
        May 23, 2017
        Cedar Rapids, IA
        Local Time:
        5:44 AM
        '76 Duster
