are ya still sposed be spin them with your fingers? bout half a turn thay start gettin hard to spin?Generally, hydraulic roller lifters require more preload than a flat tappet hydraulic lifter. Between 3/4 and one full turn is good.
yeah its more of a chevy thing...I never have used that method. It's misleading. I get all the vertical slop out of the pushrod and call that zero. Then I make the adjustment.
PS if you have a oil priming tool it never hurts to pump up the lifters before you start .To answer your question you should be able to spin them but they should resist ,If you can't spin them you probably have them too tight , it can be tricky to find the right starting point to add the preload to , be very aware the pushrod located properly , all the adjusters should have roughly the same amount of extension from the rocker as well .
Yep, I like it and would follow those instructions if using Hughes hydraulic lifters. It is a variation of what I would use after knowing the specs for any hydraulic lifter I install.The Hughes description is an interesting way to set preload.
