Hyperspark and Sniper
dart_man440
Mopar 4 Life
Arizona
Hello everyone,
I've been looking at the Sniper kit for a while, I was trying to get the full set up however, I cannot find the Hyperspark kit in stock tried calling Holley and no luck, even Summit say they wont have it until sometime in May. Anyother system compatible with the Sniper? Thank you guys,
MSD Pro Billet will work. It has to be locked out and add adjustable rotor to work with timing control. I personally would wait for the Hyperspark if you are new to efi tuning. It's suppose to make it easy, drop in and go.
Thank you, will probably do!
@dart_man440 check this out.
Yeah, ANY UPDATES??
This thing looks cooler then a witches tit on the sunny side of a Glacier :thumbsup: :popcorn:
Another easy way to get locked out timing on Mopar engines for EFI conversions: Use a Lean Burn distributor.
