Dead set against a bump in the hood are ya? I don't blame ya.Here’s a picture of the fenders mocked up. You can see how much higher the engine sits, it’s going have to go down.
It’s not going to be built with a bubble in the hood, not while I own it!Dead set against a bump in the hood are ya? I don't blame ya.
cripes, didn't realize there was that much to redo.Well, the way the setup is now I’ll have adequate ground clearance. Second, the dry sump cost is between $5-10K. And third the gen3 Hemi drives the oil pump off the front of the engine in a sun/planetary configuration, so I would have to tear down the front of the engine which I don’t want to do. Is that enough reasons for you?
And then there will be the additional fab required to mount the dry sump.
sorry, not that well off, but thanks for the offerKursplat, now if you really want me to run a dry sump I’ll give you the name of the company that makes them for gen3 hemi’s. And I’ll graciously accept that dry sump from you cause that’s the kinda guy I am.
you might test fit with the hood....on the A bodies, the hood actually bows up. With the engine installed, glancing across the fenders I think...uh-oh!, but upon adding a column of plumbers putty to different spots on the intake (for a gauge) and shut the hood....amazingly there is a good 1/2" of clearance. Naturally, the factory hood insulation is always first to go.
I would guess (I'm good at that) a custom, shorter oil pan / pick-up would be way cheaper and could be a massive gain. The question on how much gain is....how far is the sump now below the bellhousing?. No sense in anything any shorter than the bottom of the bell. With the rack / pinion out front and sans the factory steering linkage, shorten the pan / pick-up and add capacity out the sides and forward of the rear sump it appears you have. Kinda like a short, fat dragster pan.
you might be in better shape than you think. I hope you do not mind the chime in, hate to be that rail-bird helper....lots of ideas / no solutions.
Those are some awesome looking welds.Got the motor mounts fabbed up and fitted. Engine gets installed next week.i
