furydan
not so junior member
Ok...It seems I've lost a connector off of one of the cables that connect to the starter. Does the small red one connect with the brown wire at the starter or does the small red one connect with the big red wire at the starter.
My FSM shows the small red wire as a black wire from the starter relay to the battery. I just dont remember the size of the end that came off of the wire or else I would know where it came from. The small red and the brown wire are bundled together all the way up to the starter relay. At the relay, the brown wire is hooked to the solenoid terminal and the small red one is hooked to the Big positive terminal with 2 other wires.
Yes I will redo both connectors in the end. Excuse the crimp on connector..PO did it.
