NorthernSwede
Ok, Here's the Specs. And yes I've thought them through quite a bit.
Block - 318
Heads - Stock 360 heads with smoothed ports, just smoothed not ported.
Intake - Edelbrock Performer
Pistons - Keith Black ICON Forged stroker pistons .030 over
Crank - MoparPerformance Heavy Duty cast crank
Camshaft - Int @ .050 = 203 Exh @ .050 = 219 Lift = .422Int/.462Exh
Ignition - Stock breaker Ignition
Exhaust - Stock 1966 A-body manifolds and 2" exhaust with x-pipe and no mufflers
Carburetor - Holley 650 DP
Compression Ratio - 9.2-1
As you might notice I'm going for high gas-speeds and big cubes for a lot of power right from the start.
Desktop Dyno gives me 277HP and 441Ftlbs
Best regards from Sweden
Block - 318
