straightlinespeed
Sometimes I pretend to be normal
Are W2 heads strictly for racing applications? Do they require special valve train components?
Thank you guys for this info.. I was simply curious and after finding out the info provided I will probably be going with EQ heads, if I need them.
I will never understand this. If you don't have heads, why not W-2's?? You will spend just as much correcting geometry, buying aftermarket rockers and all that and the W-2's make WAY more power. Rockers cost the same (unless you are using stock junk) manifolds cost the same, headers cost the same. I just spent a buttload to build Pcar heads so I know. I have W-2's sitting there now. I can tell you had I had the w-2's from the start I would not even have looked and a production head. Even with all my port work, all my testing of valve jobs etc, the W-2's will be 75-80 HP better if I never lay a grinder to them. You are much more lift limited on Pcar heads. They don't have enough cross section, especially if you are using a stroker deal. The exhaust port SUCKS, BLOWS, STINKS AND SMELLS TO THE END OF THE WORLD and no amout of welding and grinding will ever fix that.
So I would say to you to stop and reconsider.
Spend your money once.
BTW, it wasn't a dumb question. It's very valid. Just do ALL the math and cipherin' before you spend any money.
If you already have crane adjustable rockers you just need to buy offset intakes, don't you? That would help keep cost down.Where do you get W2 rockers cheap?
You can't even remotely compare EQ heads to W-2's worlds apart..
Since Im already running stock magnum heads (which may be cracked), I already have all the valve train geometry, and hardware to run the EQ's so Im money ahead. Im not looking for high performance 400+HP. Just a simple 9.5 compression engine to cruise with.
Now if I was building more of a race car, sure I would go with the W2's and probably spend the money on them. I know someone that has a set of them they did not use, and said if I wanted to run them I could buy them from him. I just knew nothing about them, other than more performance.
