wazoo64
I need a shop in SoCal that makes/repairs narrowed rear ends. Anyone know of good shop that can do good custom work? Preferrably south of LA.
Thanks
Thanks
Bump.
Here you go. These guys are quick too. We bring a center in to them and the next day it's ready. Great guys to work with. Tell them you heard about them from Inlandmopars Car Club.
http://www.gounitrax.com/
I ended up sending the car to Sutton Engineering. Ed seems to really know his stuff and jumped right on the project. Here is what he planning. How does the price sound for parts and labor? 2k for the list below.
Axles
Housing Ends replaced/trimmed with new bearings and seals
Wilwood brakes installed and plumbing
Pinion set with heim joint links???
Fresh Paint
That with the car AT his shop. So Ed is removing, cleaning, replacing, assembling everything himself. Most gear guys just hand you the rebuilt stuff you you have to assemble and install it. Or you go to a repair shop which they will send out the rear end for narrowing, upmark it to you, then install it.
By going to Ed you are cutting out the middle man. And most of all he understands the technical side of what is going on.
I asked someone about last night for you. They also recommended Ed. And they said a lot of rear end guys just do gears themselves. But they have their axles and housing done by Ed.
Yes he is doing all the work at his shop. Seems reasonably priced if it is done right. The cost for the brakes and axles alone would be around $1200.
