I Need Help!!!!!!
twinguy
New Member
I can't get my dodge dart 1974 to start. It has a slant 6 225c.i. with a 1 barrel holly carb. I lined up the timimg chain to exact specs, changed the spark plugs, and fuel pump. Every time I tried to start it, it cranks but won't turn over. I am lost. PLEASE HELP!!!!!!!!!!!!!!!!!! Thank you.
do you have spark and gas?
spark plug wires going to the right spark plugs?
Try the ballast resistor located on the firewall. When they go bad the engine will keep cranking but will not start. Very in-expensive and always a good idea to have a spare.
THis is the right approach.Start with the basics. Confirm that you have spark,fuel and compression. Dont panic,we'll help!
As mentioned, spark, fuel, compression
My 2 cents, use/buy a test light before throwing money at parts that may not need replacing.
