bobscuda67
My daughter is home from school until the 12th. and she has a 2002 Pontiac Sunfire. One of the rear brake lines rusted out and leaked. I replaced all the rear lines and bleed the rears out. The pedal is good and firm and it stops straight. There are no dash warning lights on. But when you step on the pedal firm to stop quicker on dry pavement, there's a pulsating noise coming from the back. Doesn't do it on normal stops. I took it on a snow covered parking lot and locked up the brakes and the ABS works like it should.
Is there something I'm missing in the bleeding process? I read online that some cars have to have the ABS motor reset after opening up the brake system. Could that be it?
I would be grateful for any help someone can offer.
