k3522
Recently purchased a 1969 Dart Custom in great condition from a very honest person. He did great work. It has a 360 with a cam and AVS carb with manual choke. The good is from take off to any speed it runs great.The only drive issue is slight surging at low RPMs in drive at 55 mph.
The problem is idle at 1000 rpms is troublesome and when idling at this speed putting in to drive or reverse can stall it. The new TTI header have some discoloration which may indicate lean or rich, but it run great. WHAT DO I DO TO SOLVE IDLE.
Retard timing, decrease vacum advance, lean idle screws, buy a new carb?
