idler arm question
AdamR
Big Member
Bethel, CT
My idler arm has a bunch od play (up and down in the pocket) Are there shims that go in the Kframe ? All I have is the foam gasket.
Yes, there should be 2 washers that go top and bottom of the idler arm sleeve to take up slack.
Yes, what they said. Bring the idler & arms bolt and and make sure there not to wide. The gasket may be a good ref. to bring along as well.
I have a tool box draw full of washer and a drill press. I'll find or make something.
