If you’re going to buy a puller….
like_A_pike
that's not factory
Western WA
Which one would you say has the most applications for our A bodies? Meaning, do you have one that is your go to for tie rod ends but can pinch hit in multiple other jobs too? you’ve abused it for years and it’s still working fine.
Thanks
Thanks
pickle fork. seriously, that's the only one that'll stand the test of time and abuse.
one like this style will work, but expect to break it on the lower ball joints.
if you're not doing the work day in day out, buy this set:
it'll do everything you need and the price isn't bad.
A hammer to the side of the boss the stud goes thru will normally release the stud from the boss. No special tool required. Loosen the nut and leave it on the last couple of threads to prevent it from completely dropping out and give a couple of wacks to the side of the boss and the taper should release. Pickle forks will damage the boots. Do not hit on the stud itself.
If used properly they will last your life used infrequently.
Use it to apply pressure, no impact. Then place a hammer on one side of the knuckle and give a light tap to the other side.
No need to go all medieval on it.
light heat can help too.
Throw the pickle fork in the trash.
me caveman. me break tools.
you'll pry my pickle fork from my cold dead hands.
oh and for clarity, it was the hinge pin that snapped on that thing. replaced with a grade 8 bolt and it's been fine since.
i, however, remain a hamfisted neanderthal.
I rigged this up to apply pressure and then a dead blow worked. Well 3 out of 4 anyway. I had to screw it on one of the lower ball joints and whale the crap outta it. I can’t do the same with the tie rod ends though…
i use the fork tool thing all the time mine i german ..has 2 holes for differnet lenth bjs
but had it crush the top couple of threads always just hit the spindle taper with a bfh but hate to leave dents in classics and dont work on alloy spindles
Whatever you decide on, make sure whatever tool it is, is one that won't hurt the boot. Because not every time you need to separate tie rods do they need to be replaced. There are other instances where you might remove them.
Two hammers are needed to release a tapered fitting. One to shock it and one to back it up. Not always but very helpful if you can do it. Keep beating it. It will come loose.
[/URL]
Any of those can break, especially if you never lube the threads. Remember the last one you borrowed from Advance, they're always wirn out or broken way too soon!
Any puller needs threads, points & cups Lubed. I usually use Anti Seize, and a little heat always helps more than Impact Hammering if frozen.
