Yes, and one thing that traps a LOT of guys is that "ignition run" (IGN 1) goes COLD during "start." Therefore the only power to start the car is the resistor bypass circuit, IGN2. Even if you use an MSD, HEI or other system with no ballast resistor, you must connect the old IGN1 and IGN2 together
Also keep in mind that IGN2, which is hot only in start, is a SEPARATE circuit and switch contact from the "start" contact/ wire which fires the start relay.
The other little tidbits about Mopar ECUs is that the early boxes were what has become known as a "5 pin" box, so:
The early boxes REQUIRED a 4 terminal ballast or "dual" ballast, and had 5 active terminals. One of the resistors fed power to the box.
The later boxes are known as a "4 terminal" box, but THEY MIGHT HAVE 5 physical connector pins. This means the only way to tell a 4 pin from a 5 pin is to use your ohmeter to find out if the 5th pin is a dummy, or connected in the box.
A 4 terminal box CAN use EITHER 2 or 4 terminal resistor as the second resistor is not functional with a 4 terminal box.
The two resistors are different resistances. The way to tell, is to look at the resistor, one end of which has a "U" shaped cutout to identify one end of the resistor. The wiring diagrams (good ones!!!) are marked in the drawing.
4 and 5 pin drawings:
In the drawing below, the 4 pin ECU does not need the left side of the resistor. The "U" cutout on the resistor at the bottom in this drawing
