Ok, I've finished pulling the 318 out of my 1987' dodge truck today, going to clean it up and put on an aluminum intake and 4 barrel and tweak some other things before I drop it in the 64 barracuda.
Now to my question, obviously the 273 had points. What will I need to do to get it running using my original wiring. All the wiring in the car is in great shape. I do plan on upgrading but not just yet. I'm not very knowledgeable on electronic ignitions at all,especially putting an engine in a car that originally had points, so any help here will be greatly appreciated.
As far as the motor mounts and brackets go I have not decided if I will add a piece of metal the passenger side bracket that came off the 273 to be able to use it on the 318 or just order from schumacher. I'm curious to hear the experiences from other FABO members on both sides. What has been your experience with dealing with schumacher vs adding metal to the bracket. Has anyone that has added metal to the bracket had any welds break or crack and so on.
Thanks again for everybody's input. I hope to have it started and running before the end of spring.
