I just wanted to pass along information for those who wish to repair damaged/ burned out ignition switch harnesses. Well, the repair is as close as the local Radio Shack. Don't look in the crimp connectors and terminals as I did, look in the interlocking connector draw. The large male pins are part # 274-151 and are .125 in diameter, the 12 position small pins are part# 274-232 and are .093 diameter. There are many packs of the small pins but only one set of the large male pins. They do carry matching female pins too. Now the tools you will need are Matco tools MC93150 for the large pins, Waldom W-HT-1921_P for the small pins. I know there are other tools but these are the ones I used so I "know" they work. For the large pins use slot C for the wire crimp and slot B for the insulation. The small pins use slot B for the wire crimp and slot A for the insulation. If you do not use these particular tools make sure you get "open barrel" crimp tools. Hopefully the administrators can make this post a sticky.
