ignition switch question
moparfanatic56
0quawka, il
I have a 72 dart swinger and there is a switch right above the ignition switch with 2 wires attached to it and when the key is inserted a lever pops up and pushes a spring loaded arm up. The question I have is this for a buzzer indicating that the key is still in the ignition when you open the door or is it something else. i need to know before I put the column back together because one of the little plastic pins that holds the arm in place broke and it is not centered over the arm that pops up when the key is inserted. I have a picture of the part in question. Thanks
Please post another photo the one here is too blurry to see any thing.
But yes the little switch is the key in buzzer switch.
Yea sorry about the picture cheap camera. I did figure out that it was the key buzzer so I just took it out as it is not going to be a concourse restoration just a driver. Thanks for the reply I appreciate it.
Interconnects with horn relay which is the buzzer. Horn relay has a 4th terminal for the "key in" circuit.
Not if done correctly. I believe it's just the 4th terminal. Earlier relays had 3
