ignition switch question
cwshafer
!GaNCEC43teacher
Hello, I have a 1969 dodge dart Custom with 318 that I pulled into the garage after a carshow and it has not started since. It has an aftermarket key switch that also uses a push button that has over the years wiggled loose . As it wiggled 1 wire came off must be run, but when i dropped it down from under the dash 2 more fell off so I am rehooking it up , I need to know where the factory wire colors went because the back of this switch is clearly marked and the original wiring is basically in tack.
mymopar.com has wiring diagrams and FSM free download and also classiccarwiring.com has color coded diagrams to buy, best 25.00 I ever spent.
This is 67 Dart (69 might be different) traced out from my Classiccarwiring.com print
Brown is the ballast resister bypass (IGN2)
Yellow is starter really trigger (ST)
Dark Blue with Tracer feeds the voltage regulator and the ballast resister (IGN1)
Red is main power in (BAT)
Black feeds the accessories (ACC)
Does this help?
