jbc426
With the thicker Schumacher motor mounts, the transmission centerline was at 0 degrees. My pinion angle was 2 degrees nose down.
That must have been someone else that stated US Cartool is going to make a lower mount. Ground clearance is fine on my transmission. My exhaust use to scrape on very tall speed bumps before I switched to TTI step headers and their 3 inch H-pipe exhaust.
I am swapping factory rubber mounts back in and using the Schumacher torque strap to hold the motor down to avoid breaking the front mounts and get rid of the engine vibration that is fed into the chassis with their harder mounts. This will slightly change my transmission centerline from 0.
Once I find out what that is, I am going to shim the rear end so that it is just under 1 degree nose down in relation to the transmission centerline. This way both ends of the driveshaft will have nearly equal angles, but the pinion angle will be slightly nose down in relation to it < 1 degree to allow for upward rotation under throttle. It was at 2 degrees nose down before.
Must have hit post twice.
