Small change here and there..... LOL
I'm liking it !We have plans.... !That's great to see! What are your plans for the car from here? What is your shift and trap RPM?
We had a blast today... again!Great job! That's cooking for such a mild combo.
just gear change. The SM heads OOTB in place of the factory 360 heads brought me from 13.3's to 13.13. To be fair, the cam is way to small to take advantage of the heads.Quick question. Was the pickup into the 12.90’s from the gear change only or were the speedmaster heads just added too. Great job and nice video.
Just working with what I have..... mainly..... all in fun !With a one wheel rear and no tach you are leaving a bunch out there to pick up.
The car sounds good going down the track and tons of fun will be had with it!
Why are you concerned with ET’s and running Open rears with 2.9 and 3.23 gears? Just seeing what’s possible with plain pieces? I’m new to your project so sorry if I missed it of you already stated the goals.
I’d like to add his is working from a minimalist stand point. AKA - Do the best you can with what you got. Then add something to it. Minimally. He works the basics with what the car was born with and moves forward.With a one wheel rear and no tach you are leaving a bunch out there to pick up.
Doug headers, and if my memory serves me correct (don't bank your $$ on that!), the SM heads are 65cc. I used the fel pro 050 thick head gaskets so it would be the same as the cast heads had, for comparison.I didn't see, but does it have headers? What CC are the chambers?
thank you, your words are too kind. Can't wait for the day that your Dart makes a pass. And I truly mean that....Man that's awesome thanks for sharing! I knew you would make it into the 12s this year its still extremely early. You will be in mid 12s by summers end! Like I said before you behind the wheel is worth a half a second! That's a 13.5 combo and your running 12s lol
Hopefully it won't be too long! I'd like to make a few passes before summer is over. I will take it easy of course shift at like 4k lolthank you, your words are too kind. Can't wait for the day that your Dart makes a pass. And I truly mean that....
I'm cheering for ya, brother! I so want the best for you for all the labor, sweat, blood, and persistence you poured into your Dart.Hopefully it won't be too long! I'd like to make a few passes before summer is over. I will take it easy of course shift at like 4k lol
you'll go faster than mid 8's... be patient and tune it, not only the motor, but the entire car!We only have 1/8 mile around here I would be tickled to death with a mid 8! I think that should be very doable. With 3.73 and a mildish 360.
