[FOR SALE] Indy 440 SEZ Heads
Frank Mopar
Lackawanna, NY
440 Indy heads. Posting for a friend. Here is info. I have seen the heads. They are beauties. Hit me up and I can give you the phone number asking $3500 Angola, NY
The as cast 440 SEZ Indy head incorporates the original design raised intake runner and Indy aluminum valley plate. Stock 906 paper intake gaskets, stock exhaust gaskets and stock rocker arms are used. Angle spark plugs with standard low exhaust port and bolt pattern. This is a cure for the common clearance problem!
