abdywgn
dismantler
will the combustion chamber shape accommodate the early 340 factory "domed" pistons?
This is important.... there are several variations that effect piston heights: rod lengths, crank grinding accuracy and so forth. If the 340 pistons are .020" out of the hole in a coupla spots, the .053" gaskets will be a bit marginal IMO.Depending on your deck height and rod length they could be anywhere. Measure them all in the 12, 3, 6, and 9'oclock positions to be sure.
