I've have an LA 318 that I set up to use magnum heads on years ago. I'm going to replace the heads with Indy X heads. Question is, Do I buy the LA-X heads and go back to LA rocker arm shafts or the MAG-X heads and continue using the magnum rocker arm setup I have now? It's just a mild 318 going in my cruiser and may be subjected to the occasional burnout. Any advantage to returning to the rocker arm shafts? When I put this together several years ago the LA style magnum heads were not available yet. Thanks
