D-mailman
Anyone running INDY/RHS LAX heads on their 408 stroker ? Thanks for your input.
Terry
Terry
Terry
I have heard nothing but great things about these heads but I have a question.
Wouldn't it be better if they were aluminum so in addition to the obvious weight
savings, you could run at least another point of compression?
In theory heck yeah ,however in my case I'm not allowed to have aftermarket Aluminum heads on my motor and still maintain my Collector plates and the cheap insurance that goes with them so these iron LA heads are the cats backside .
Ditto on the reviews... We went with the Edelbrock Performer RPM heads for this exact reason..... lower head temps and added detonation resistance. The lighter weight of them plus an AL intake shaved a total of 70 pounds off the car's nose vs stock iron.I have heard nothing but great things about these heads but I have a question.
Remember that extra point is restoring the heat that the aluminum takes away. You're not getting more bang for it - just getting back to where an identical head made of iron would be.
Aluminum vs iron always always always comes down to value - meaning cost vs reward. If someone places a higher value on initial buy in cost than some of the benifts aluminum will never make sense. Personally, if better heads are needed, no way I'm paying to run iron.
Seriously not trying to start any argument, but that simply is not making sense.... not sure it was stated as intended....?? The higher compression ratio indeed results in higher cylinder pressures and higher combustion temps, regardless of the head material, and thus more torque across all RPM's (as with any higher CR). The AL heads run cooler simply due to a thermal conductivity that is 3-4 times better than cast iron up at engine operating temps, not due to any difference in the the combustion temps by themselves.Remember that extra point is restoring the heat that the aluminum takes away. You're not getting more bang for it - just getting back to where an identical head made of iron would be.
moper said:Any heat lost to the cooling system is lost power. That's why thermal barrier coatings are all the rage (and coated chambers). I would agree the effect is probably not going to "1 to 1", but the reason one can run more compression is because more of the heat is being wicked away. If you can find me two heads identical in every way but the material I'd be interested in seeing the results. I said identical heads for that reason. No arguement here. It's scientific fact and thus far I haven't seen it seriously challenged because there are no complete apples to apples comparison. Whether someone buys into it or not makes no difference to me.
Have you gotten yours back together after the head gasket problem ??
