4spdragtop
Ok so i checked/confirmed rotor for ccw spring back when rotor is turned cw. I can twist about the width of a reluctor tooth, maybe slightly more.
Set reluctor gap at .008, was tight in places.
Looks like blue and red spring?
Orange pad under rotor.
Yes that is the ported vac. Vacuum should be zero at idle and increase when the rpm's go up. Honestly I dont know if that is the one I sent you what color is the pad under the rotor? I use a different color just for this.
