KW-Duster
Active Member
I have what appears to be an Inland 3-speed shifter. Came with early 70's duster parts that I acquired. Disassembled to clean up. I took a few pictures but obviously not enough and I have a few questions.
-Is there a rebuild kit for lockout spring and shims available? (this shifter I believe is a A230 handle mounts on the top with three bolts)
-Does anyone have a diagram on how to reassemble? (Should have taken more pictures)
-Should I media blast housing and linkages or just soak to get rust off?
-Once it is cleaned up should I paint (except where linkages slide together) or coat in something to prevent rust from happening?
Thanks in advance for the advise.
