1. Bobacuda
    Bobacuda Well-Known Member
    100
    139
    Dec 1, 2017
    Texas
    Local Time:
    11:07 PM
    Looking at getting preformed brake lines (front to back) for my ‘67 Barracuda and I was looking at their ads...then I saw a lot of bad reviews. Anyone here have experience with them?
  2. billccm
    billccm Well-Known Member
    103
    69
    May 13, 2018
    Tucson
    Local Time:
    9:07 PM
    My experience was not good. This one item in my disc conversion cost me 6 weeks. Wrong parts in the box, and asymmetrical flare was a nightmare.
    My recommendation would be to check Dr Diff, or make your own lines.
    • Agree Agree x 1
    • Mattax
      Mattax Just the facts, ma'am FABO Gold Member
      9,478
      5811
      Feb 7, 2013
      Phila. Pa
      Local Time:
      12:07 AM
      My experience with getting a fuel line for my '67 Barracuda coupe.
      This was for a 3/8 St St line, but I wanted it to fit exactly as the original 5/16 line:
      1. Fine lines's had flat cross sections in the bends. They had no interest in the details so I just sent it back. No point in using 3/8 line if the tubing cross section is reduced.
      2. Classic Tube didn't fit right. I think there was a change between 67 and 68 or 69 in the routing and clip locations.
      3. Inline Tube was pretty much OK.
      A little more about that saga here
      Good/Bad Experiences when changing to 3/8" fuel line & sending unit?
      • Like Like x 1
      • Thanks! Thanks! x 1
      • Dusterdenovo
        Dusterdenovo Contentedly Old School
        938
        1748
        Dec 10, 2011
        British Columbia
        Local Time:
        9:07 PM
        73 Duster. Brake lines and fuel lines fit great. Would use them again without hesitation.
      • 72bluNblu
        72bluNblu FABO Gold Member FABO Gold Member
        10,169
        4611
        Nov 28, 2008
        NorCal
        Local Time:
        9:07 PM
        The 3/8” fuel line on my Challenger and my Duster came from inline. I also bought parking brake cables for my Challenger. Shipping was expensive and took a little longer than some places but all of the parts and lines were spot on. I’d use them again, I form most of my own brake lines but the long, larger diameter front to back lines (like the fuel lines) are nice to get preformed.
        • Agree Agree x 2
        • Cuda Al
          Cuda Al Well-Known Member
          965
          1041
          Oct 21, 2007
          Lompoc, CA
          Local Time:
          9:07 PM
          Inline Tube, no problems.
          67 Barracuda, OE style, OE brakes
          Both fuel line and brake lines.
          Alan
          • Agree Agree x 1
          • 66 CUDA
            66 CUDA Well-Known Member
            1,685
            488
            Aug 20, 2009
            Clarkston Michigan
            Local Time:
            11:07 PM
            Every line on my 66 was replaced and I bought them from Inline Tube, they all fit perfectly. Now I am picking up lines for the 68 and so far so good.
            Bob
          • my68barracuda
            my68barracuda Well-Known Member
            1,093
            754
            Dec 6, 2009
            Indianapolis IN
            Local Time:
            12:07 AM
            I put inline tube brake lines on my ‘83 D150 and ‘68 Barracuda,
            The fit was fine, no issues with either of the installs.
          • straightlinespeed
            straightlinespeed Sometimes I pretend to be normal Staff Member FABO Gold Member
            9,846
            3170
            Oct 21, 2012
            Oakdale, MN
            Local Time:
            11:07 PM
            No problems with inline tube for me.
          • abodyjoe
            abodyjoe Well-Known Member
            20,341
            5254
            May 22, 2004
            Berlin,N.J. 08009
            Local Time:
            12:07 AM
            used a inline tube kit for my express truck and all the steel lines fit perfect.
          • 72bluNblu
            10,169
            4611
            Nov 28, 2008
            NorCal
            Local Time:
            9:07 PM
            One thing that would come in handy is a tube straightener. The long front-to-back lines come folded in half or more for shipping, so you have some bends to straighten when they go on the car. It's not a big deal to do without a straightener, but if you're a little OCD you'll get a better looking result if you have one.
            • Agree Agree x 1
            • daffyduck
              daffyduck Member
              11
              0
              Mar 2, 2016
              tampa florida
              Local Time:
              12:07 AM
              have used inline for 3 of my cars, brake and fuel, no problems
            • 1969383S
              1969383S FABO Gold Member FABO Gold Member
              5,226
              2276
              Jan 8, 2012
              Cumming, GA.
              Local Time:
              12:07 AM
              Inline worked very good for me. Upsized to 3/8 fuel and standard brake lines. Used the standard type steel tubes and the only issue for me was tighten and re-tighten the brake fittings, sometimes a few times. They need that to seat correctly.
              • Like Like x 2
              • 1969383S
                5,226
                2276
                Jan 8, 2012
                Cumming, GA.
                Local Time:
                12:07 AM
                The inline 3/8 fuel was a bit tough at the transition from rocker up the rear rail. Patience helps as it a full piece and the last rocker clip was tough to engage. Brake lines were pretty straight forward and fit Very well. Just getting them to seal was a little frustrating. I try not to over tighten them and seemed good torque and re-torque a time or more was the answer. KH disc and rear drum.
                • Like Like x 1
                • cosgig
                  cosgig MoBro Inc. FABO Gold Member
                  11,172
                  4105
                  Jul 20, 2008
                  Pinckney, Michigan
                  Local Time:
                  11:07 PM
                  I bought and paid for all of my lines from Inline at the Nats last year. The lines were shipped immediately, but they forgot to put the rubber flex lines in the box. It took me 6 weeks, more than 1/2 dozen phone calls and emails sent with pictures of my handwritten invoice from the Nats clearly showing that I paid for them before they shipped them to me. And, I live in Michigan, about an hour from them.
                  • 69hemibeep
                    69hemibeep Well-Known Member
                    269
                    84
                    Jul 18, 2010
                    AZ
                    Local Time:
                    9:07 PM
                    3 cars now no problems
                  • 1969VADart
                    1969VADart FABO Gold Member FABO Gold Member
                    2,227
                    545
                    Aug 19, 2013
                    Fredericksburg, VA
                    Local Time:
                    12:07 AM
                    I used Inline Tube for all of my lines (brakes and fuel) when I did my car, and I have no real complaint. One small issue (though not really a complaint) was the rear brake line was not exactly bent the way it needed to be for routing around the 7 1/4" rear end, but it only took a minor modification. Otherwise, everything went together just fine.
                  • 12swinger
                    12swinger Well-Known Member
                    318
                    386
                    Jun 26, 2013
                    Hoosier
                    Local Time:
                    11:07 PM
                    Pretty much perfect fit and they look nice in stainless. Put them on the Challenger recently on a resto. Almost done.
                    Here’s more pics!
                    • Agree Agree x 1
                    • 72bluNblu
                      10,169
                      4611
                      Nov 28, 2008
                      NorCal
                      Local Time:
                      9:07 PM
                      Stainless is the way to go! Spendy but I figure do it once and never again.
                    • DentalDart
                      DentalDart Well-Known Member
                      1,565
                      1053
                      Jul 5, 2019
                      Las Vegas
                      Local Time:
                      9:07 PM
                      I havent had any problems with them installing their hoses right now. Dr Diff reccomends 1969 Camaro hoses if you're doing or have disc brakes on a 67-69 and it may be a better choice I dont really know though.
