67Dart273
Also, "the book" shows installing with special toll blishi blashi which says to the effect "using tool xxxx properly positions the seal in housing to properly contact axle sealing surface."
I don't recall, anymore, if there's a shoulder for the seal to sit against (probably not) So measure the depth to be sure the seal is actually "on" the seal surface when installed. The fingerfull of grease to lube the seal will have no effect on axle lube.
