INST Fuse blowing
Discussion in 'Electrical and Ignition' started by moparmandan, Jun 10, 2018.
  1. moparmandan
    moparmandan FABO Gold Member FABO Gold Member
    620
    307
    Jun 28, 2017
    Central FL
    View My Photos
    Local Time:
    7:59 AM
    Got back on it today for a while. Traced the orange wire to the radio light, heater switch light, gear selector light, and ash tray light. Wire to the ashtray tray light worn slap through grounded to the frame right behind the bulb socket. Score!
    Now for the orange wire that goes to the dash lights. Still reads short to ground. What do you think? All the cluster lights worked during bench testing. Where's the most likely place for that wire to be grounded?
  2. MOPAROFFICIAL
    MOPAROFFICIAL Well-Known Member
    1,912
    982
    Jun 1, 2016
    breakwater
    Local Time:
    4:59 AM
    Check gear select and amp gauge
  3. MOPAROFFICIAL
    1,912
    982
    Jun 1, 2016
    breakwater
    Local Time:
    4:59 AM
    2 orange wires come out of the one fuse one goes to a split off ,the other one goes to the Gear select...forementioned split-off goes to a white wire that goes to your bulkhead it looks like it ties/piggy backs to a black wire that goes off to ...either the parking brake , printed circuit board connector ...or the turn signal cam/switch..
  4. 67Dart273
    67Dart273 Well-Known Member
    36,588
    4521
    Oct 14, 2010
    Idaho
    View My Photos
    Local Time:
    4:59 AM
    Is this with the cluster unconnected? If not just about has to be "right in" the cluster
    • Agree Agree x 1
    • 67Dart273
      36,588
      4521
      Oct 14, 2010
      Idaho
      View My Photos
      Local Time:
      4:59 AM
      This is incorrect and I already addressed this earlier. What you are seeing is the radio power connector. The white and red are connected, not the orange. Orange is unique in Mopars it is "only" connected to orange
      ^^This what you are looking at?^^
    • moparmandan
      620
      307
      Jun 28, 2017
      Central FL
      View My Photos
      Local Time:
      7:59 AM
      Delete
    • moparmandan
      620
      307
      Jun 28, 2017
      Central FL
      View My Photos
      Local Time:
      7:59 AM
      No it is still connected. I think you are correct sir. I'll pull the cluster back out and see what's going on. Thanks a lot for your help, it ain't long now!
    • moparmandan
      620
      307
      Jun 28, 2017
      Central FL
      View My Photos
      Local Time:
      7:59 AM
      Thank you. That's the same thing I was thinking. I really appreciate you pointing out the differences in the mymopar color coded diagram and the FSM. I would have been chasing my tail.
    • moparmandan
      620
      307
      Jun 28, 2017
      Central FL
      View My Photos
      Local Time:
      7:59 AM
      Unfortunately I think you got caught in the same trap I did. Evidently there are some inconsistencies in that wiring diagram. The service manual is really the thing to use when troubleshooting the wiring. Thanks for trying to help though. It is really appreciated.
      • Like Like x 1
      • MOPAROFFICIAL
        1,912
        982
        Jun 1, 2016
        breakwater
        Local Time:
        4:59 AM
        Yeah, i sourced that from the same site apparently. There used to be a site i used, bookmarked it, would print diagrams... That were accurate... haha... it's gone now and all I have left of prints are 1971 dart, I could have referenced it but it wouldn't be 100%correct.
      • MOPAROFFICIAL
        1,912
        982
        Jun 1, 2016
        breakwater
        Local Time:
        4:59 AM
        Right on, yeah when i see threads go on a bit without resolve I feel obliged to try offer any help i can.
      • 67Dart273
        36,588
        4521
        Oct 14, 2010
        Idaho
        View My Photos
        Local Time:
        4:59 AM
        It's easy to do there are "unclarities" in the factory prints and also some mistakes over the years.
        One mistake for several years involved the horn and start wires going through the bulkhead connector. They magically were connected on either side of the connector LOL
        And "Ma" never made any real effort to describe some of the odd stuff, and the seat belt interlock is a great example.
      • moparmandan
        620
        307
        Jun 28, 2017
        Central FL
        View My Photos
        Local Time:
        7:59 AM
        What's your best guess on "right in" the cluster? Sitting here brainstorming at work on break..............
        All sockets and bulbs new.
        Amp meter bypassed.
        5v factory voltage reg replaced with a 7805.
        Fuel level and temp gauge seem to work.
        As removed:
      • 67Dart273
        36,588
        4521
        Oct 14, 2010
        Idaho
        View My Photos
        Local Time:
        4:59 AM
        Can't see what you are trying to post. I would just take it apart and inspect it. Might be something like, part of the connector pins "pushed through" and touching the cluster frame underneath, "I guess" it could theoretically be a shorted bulb, though I've never seen one.
      • moparmandan
        620
        307
        Jun 28, 2017
        Central FL
        View My Photos
        Local Time:
        7:59 AM
        Thanks. Will do. Looks like we lost power to the tan wire also. Probably took out the headlight switch because we don't have running or tail lights now either. But we have power on both sides of fuse number 5 , the tail light fuse. No biggie already picked up a new headlight switch.
      • moparmandan
        620
        307
        Jun 28, 2017
        Central FL
        View My Photos
        Local Time:
        7:59 AM
        Corrosion in the tail light fuse slot. All dash light working.
        Now just fun stuff. My son said the key in ignition buzzer is the most annoying thing he's ever heard. LOL
        Ashtray light working. Wipers work great, park great. On to the glove box and dome light!
        Oh yeah, one question. Where the hell does the heater control light plug in? Forgot to do that while everything was apart. Oops. Am I going to be able to get my hand up in there?
      • moparmandan
        620
        307
        Jun 28, 2017
        Central FL
        View My Photos
        Local Time:
        7:59 AM
        Is that the hole? Upper left of pic?
      • 67Dart273
        36,588
        4521
        Oct 14, 2010
        Idaho
        View My Photos
        Local Time:
        4:59 AM
        Yep
