Installing boots on my Accel wires.
Snake
Mopar Nut
Belleville Canada
Ok just got my new 8mm Accel wires.Thease are the ones that I have to make my own ends at the cap.Ok looks like its going to be a tight fit sliding the wire into the boot.What could I use to aid the wire sliding in with out hurting the wire it self.In the past I bought 7mm a tad tight but slid on with no grease or anything.Thanks in advance.Don:toothy10:
Slick stuff, from hardware store. Easy, if you get it on your hand, you can't hold on to the wire.
Use the stuff that came with it..it is a dielectric gel and works very well, you don't need a whole lot jusy spread it on with your finger.
AL
sSSnake, I used the stuff supplied with the Taylors, had no problems.
Cool glad it work for ya,gosh when I first tryed the dry way no go,all is good now just have to cut and clamp tonight.PS its to dam hot here thatsss why I have stalled on installing them lol.
