ragtopfury
Not quite the easy fit on Jake's 65 that others have had....but we'll get thru it.
So we have the body where we want it ready for my paint man. Decided toswap the manifolds out for the 5.2/5.9 Dakota/Dango logs. Minor issue. I knew the collar at the steering shaftneeded to be trimmed a bit, and knew there might be a little grinding to do on the edge of the manifold to clear the shaft..... But The right side is dead against the inner fender - need to grind the pentastar and casting numbers off the manifold to clear it, but the left side is worse - it is dead against the steerinf colum shaft. So much so that the front of the manifold is pulled away from the head because the rear of it is pushed in from hitting the shaft. I think I will take them to a machine shop and have 1/16th of an inch milled off the mounting surface of both manifolds. I know it will give me what I need on the right side, and am hoping between the 1/16th and grinding the casting numbers off,along with an 1/8th inch shim under the motor mount, I'll get just enough to let the left side clear the steering shaft.
