snowmobiler7c
Just a couple quick questions. Im getting ready to install my new convertor to the trans when my arp bolts get here. After a little reading is 1qt in the convertor adequate to fill before install? I see a lot of people claiming to use Dexron Type III I don't see too many fluids that are only type III. Is the Valvoline Dex/Merc ATF sufficient? And last I believe the 904 takes 9qts if I read correctly. If im installing a deep pan will ordering 12qts be enough? thanks for any input
Mark
Mark
